Hi Folks, another novice question. I have the Glowporge Pro and when I have a design/photo open in the glowforge there’s an option to add text. The text only goes horizontal. I s there a way I can have the text go vertical?
L
I
K
E
This?
You can also center or right justify them if that looks better to you. The grid of dots tells you where the coordinates are being set. Not that I would recommend this, the UI alignment is still only a tool of last resort compared to something like inkscape or illustrator.
Yeah, it’s a joy.
I use a Word doc, print as a PDF, and if I want to tighten the spacing, I can do so in the GF as each letter can be moved on its own–but I opt to check the center position for all, in case I shift it to the side & want to make sure aligned OK again… (also I have built up a big list of fonts in Word, but there are neat ones in the GF, too).
