Hi All, I seem to have acquired quite a lot of tubs of hand sanitizer which are cluttering up the cupboard under my kitchen sink. So I quickly threw this together and thought as we’re in a pandemic this same thing might be happening to some of you.
Red = Cut
Blue = Score
Pink = Engrave
This box works for 1/4" or 6mm material and internal dimensions are W: 15cm L: 20cm H: 15cm.
FYI, everything in the Free Laser Design section is personal use only - you only need to specify if you want to give more permissions (Eg. some folks post that a design is ok to use commercially)
