Video Tutorial - How to make a jig
Hey everyone,
I put together a detailed tutorial on how to make a jig, I hope it helps you out. Took an hour to film it and about an hour and a half to edit and upload it so I hope it helps at least one person:
Looks like I’m person #6 - your ROI is looking pretty good :smiley:
Great video thank you.
Thank you. I found this helpful.
Your efforts are appreciated :slight_smile: Thanks.
thank you for not trying to make it look like snapchat with bitmojis and (shudder) bright yellow/neon pink text superimposed all over the screen.
I’ve never used either in my life so wouldn’t even know where to start but I don’t care for that either. I usually just pick a premade icon for the image from with in the video unless all three are like a solid black image or a really poor shot then I’ll make an icon that is fitting.
I am glad to see that this helped quite a few people, thank you guys for the kind comments.
I’m late to the show, but this is so helpful and I’m more hopeful using this laser. Thanks much!!
Welcome. Lots of helpful people and information here in the forum.
This was so helpful! Thank you for taking the time to make it! I’m brand new to using a laser anything, so I’m watching a ton of tutorials and videos. Greatly appreciated.
Thank you! Can’t wait for my Glowforge to arrive!
Is there any way you can do this without a digital caliper?
I’m not going to watch the video to see why they used a caliper, but I’ve made several jigs and never needed one (I have several).
Secure jig material on bed, cut outline shapes, remove cut parts, then place item to be engraved/scored into cutouts and print, repeat as needed. If you need it to be repeatable at a later time, ensure the jig material is large enough to drop into a repeatable position, i.e. against the small lip along the front and side of the crumb tray. Some people have difficulty with the crumb tray location varying. I don’t, but if that’s the case, you need to search here for solutions for that as well.
Excellent wenning08, exactly what I needed. “Sam”
Joshua, I know it takes you an immense amount of time to make your videos and design your projects. I always respect your time and effort.
No problem anytime. Thank you for your kind words.
Cool. I know how to make the jog but wanted to check out your finished skyline anyway. Still watched the whole thing.
