I was initially concerned that it might distort the honeycomb, but that doesn’t seem to be a problem.
So while I could add a ‘use it at your own risk’, I don’t really have any fears on that front.
It’s been out there for three years now, and I’ve not had any -ve feedback, so I think it’s OK.
Hi…what a wonderful file…except that it is too big to go through my honeycomb. I cut in 1/8 and 1/4 draftboard. I’m pretty new. What am I doing wrong? By chance, did the honeycomb change since your original file??
The 1/4 inch will be too thick I think, but the 1/8 should be fine. You will need to angle it down through the widest dimension of the ‘cells’ honeycomb, and it will be a tight fit.
Thank you! I will try AGAIN!
