Nothing special, just a simple engrave, and am very pleased with the results for my first attempt. For my daughter. I’ve never worn a watch of any kind. I bought four, have some more elaborate ideas in mind.
Used settings you’ll find over in BTM. Filled with latex paint.
I don’t have a ruler handy, but I do have my watch (40mm). Looks like you have about 2-3mm of overlap from the end of the band to the edge of the watch. Your design should be visible outside where the band goes into the watch case, but maybe with less clear space in between than intended.
Are you engraving the Apple bands or a knockoff variety? I’ve not found clear info on whether the fancy “fluoroelastomer” of the former are laser safe, but some of the latter are more clearly known to be just silicone.
So the paint is not holding up. It was a combined primer/paint.
Suggestions on something more durable, that can still be filled in and wiped off the surface cleanly? Am thinking a solvent-based enamel may be too hard to clean off the unengraved areas. I have plenty of nail polish…
I did a little research based on g2n’s suggestion and oil-based markers are supposed to be the best choice, The engraving does leave a rough surface behind, so that should be helping (didn’t help the paint I’d used, though!)
Going to meet some friends for dinner at a mex place next to an officedepot, I’ll pick one up. Need to come up with another design to print so I can try it out.
Well, here goes round two. Just a single application of Sharpie oil-based marker. The photo shows lots of debris but it looks perfectly clean to the naked eye. Let’s see how this holds up!
So medium point works best? Do you seal the paint with something afterwards? I got the craft mart fine point and the paint is leaking everywhere as soon as I press on the engraving with it
