@rodrigobrionesm had requested settings for Adams waterproof foam board so here are the ones I use as well as those @saben_fair uses:
mine:
As you see, I use three passes to cut through as that seems to give me the least foam pull back. A heavy score is to cut through everything but the bottom paper. Light score cuts through the top paper and not much more. I can’t emphasize enough that these are starting points.
Hear are @saben_fair 's settings"
Cuts
500 zooms
65 pewpews
2 pass
Height .085 in
