I’ve acquired a quantity of plywood material that’s very laser-friendly, and I’d like to buy more of it – but I don’t know how to properly describe it to suppliers, so I was wondering if y’all had ideas…
…it’s three-ply plywood, birch veneer two sides, single poplar core layer, 0.201 inches thick in total. I’ve got sheets that are 12x16, 12x19, and 12x24. The edges look almost perfect, so I think it was originally purchased in those sizes, rather than broken down by a prior end user (the end user I acquired it from did not have a pro-grade cabinet saw).
I took a sample to a local esoteric plywoods supplier, who said he’d never seen it and didn’t know where to find any more (this is the same guy who said he stocked “everything”). From the sizes I suspect it might be used as stock for the bottoms of cheap cabinet drawers, but I haven’t had any luck there either (I am mainly finding MDF cores, and I like the poplar because it’s lighter and not as smoky when cut).
I’d include a pic, but it’d be pointless – it’s just birch veneer plywood, poplar core, 0.201 inches thick, available in 12x16, 12x19, 12x24.
Seems like it ought to be simple to find, but I’ve checked most of the wood suppliers listed here without luck yet. It also doesn’t appear to be the same as PureBond, although I am still trying to find a decent sheet of PureBond in order to compare.
Any thoughts? It’s decent stuff, and really seems like it should be easy to find so I frankly suspect there’s some code word I’m not using when talking to people. I acquired it as cast-off material, and the person I dealt with didn’t really know much beyond “I was told to get rid of this so here it is now take it away”.
(I can attach a pic if really desired)
