Hi there,
I have researched on this topic a lot and can’t seem to find the answer. I was hoping you would be able to help me.
I had been painting wood white, then engraving pictures. However, I found white, 1/8th inch mdf and tried that. The engrave is perfect.
My issue is, when I try to cut the wood, it sometimes doesn’t cut all the way through. Other times, it cuts all the way through but will always burn the bottom line of the frame, which I realized tends to go slower when cutting than the others in the rectangle.
Would you please give me some advice?
Attaching images of the burnt area as opposed to the other side.
Thank you!
