I have been trying this ALL day and can not figure it out. I am working in Adobe Illustrator trying to complete what I thought was a simple sign I am trying to merge 3 short lines of text, joined by a line in between each line. When I move the saved SVG image into my glowforge everything disappears but the lines. What am I doing wrong?
First you have to convert the text to outlines, (just select it, right click, and Create Outlines), then Expand the lines, (select each line, then Object >Expand), then you can use the Unite tool in the Pathfinder pallet to join the letters to the lines. Overlap them slightly, then use the Unite tool. Set the Fill color to null AFTER you join the shapes, and give it a stroke color so you can see how it joined.
