So i have my GF venting outside with a 450 CFM exhaust fan, but i’m still getting fumes.
Does anyone have any experience with small room filters to scrub the air, like An ionic breeze or a hepa tower?
How long is your vent (over 10’)?
How many turns (more than 2)?
What is the diameter of your vent hose (4", 6", etc.)?
Is the fan close to the or closer to the exhaust port in the wall?
A 450 CFM exhaust should be enough, so you shouldn’t have fumes unless there is something else that is an issue (like a leak in the exhaust).
If you have leaks in your exhaust, the easiest thing is just to move the fan as close to the wall-port as you can. Then it will prevent fumes from exiting the exhaust. But that only works if you still have enough airflow to pull the fumes out of the .
@bill.m.davis is 100% right. You want your fan to pull the air, not push it. I place mine at the very end and have no fumes unless it is in need of cleaning.
Thanks Everyone. I appreciate your feedback.
