I think, for me, the “printer” part was what felt most awkward. Mostly because all of the other machines that are close to this fit into my schema for a “cutter.” Looks like I need to add a new schema to the way my brain organizes around this.
I felt that way at first too, but then I kept running across places online where people would talking about “printing” their designs, meaning cutting them with a laser cutter. I bet a lot of it was derived from the fact that quite a few machines use a print driver to send the design to the cutter (which I believe was part of that long dead horse @chrgeup mentioned), but what’s a little corpse mutilation between friends
If this topic dies, it dies. My feelings did change a bit after hearing about the potential for different heads. Still adjusting neural connections to make it fit, though.
No. I get why they use it, and I remember dan talking about how people would be all “oh i love that laser printer,” etc. But I feel like it’s giving in to the misnomer instead of educating people, and to be honest I think it’s really silly.
Doesn’t change how well it cuts and engraves, however, so whatevs.
I won’t lie, first time I read “interchangeable heads” my stomach sank a little because it sounded like a compromise on making a good laser for the sake of becoming an attempt at an “everything for everyone” machine. I don’t feel that way now, but it took a little neural reprograming to get past. Now I’m excited about the possibilities, especially if they can figure out a way to turn it into a vinyl cutter, which I don’t think would be overly challenging.
A 2" Z axis would make a very poor 3D printer (at least very limited in scope of what it can produce).
A Magnetic attachment also precludes it from it ever becoming something like a CNC that can do any hard material.
So you are left with possibly heads that could eventually raster things to speed things up, or do different angles. I don’t really see how it could in practice be much of anything unless the form factor of the unit was redesigned significantly.
I am naming my Glowforge Squishy. It save will save all of the intricate explainations involved when asked; [quote=“scatterbrains, post:1, topic:3978, full:true”]
Continuing the discussion from Is pre release units production units:
In an effort to not hijack another topic, here’s a new one.
With the announcement of the changeable head, does that help anyone with calling the product a “3D Laser Printer?” Maybe “3D, Laser, Printer?”
To be honest, it didn’t really bother me too much to begin with. It just felt awkward because it was different than I was used to.
[/quote]
I don’t believe that the Z axis has to be limited to the distance from the head to the bottom. I think the distance from the bottom to the lid glass is much greater. Still pretty small comparatively, but more useful than 2".
I also think they’ve got some smart people there that can figure out other stuff. I think they mentioned 3d printing and inkjet because those are pretty achievable. I think they didn’t mention CNC because wood bits flying around in that case might not work out so well. Cricut type of setup or something, maybe just has a clamp to lock it on after it’s attached to the magnets.
There has been discussion elsewhere on the forum about how Glowforge is calling it’s machine a “3D Laser Printer.” It came up again in the topic that I continued.
I think that’s correct. I think it’s being used as the number because that’s what the current material thickness allowance is for the laser head and honeycomb bed. But if I were to decide to put a 3D extrusion head in there, it’s possible to turn the 3D printer on its head. Instead of a bed that moves down as I build a part, how about a head that moves up from the fixed bed that is sitting under where the honeycomb sits now? That’s 5-7" as far as I can tell from seeing the machine at Makerfaires. That’s actually not a bad build volume. Making a 3D extrusion head that rides on a snap-in magnetic mount would require some motor assemblies and things that I would think are doable with what’s out there today - certainly inventable by someone who is doing what GF is doing today.
But that doesn’t make me think that a vinyl knife or some way of putting color down (inkjet or airbrush) isn’t something that I’d want first
The name bothered me during the preorder campaign, and I didn’t completely buy the explanation that they thought the name was more accessible…
Until my mom started calling it a laser printer, and she has never seen the promo stuff or looked up the website. I described it to her, and she calls it the laser printer thing.
Then again, she also asks me to ‘print’ stuff on my digital cutter.
I guess if material goes into a machine and comes out different, in any way, it’s been printed in her mind.
Yep. They must have some Z motion control in the laser head now in order to do the flying focus automagically. This would just be an extension of that. And if they make the laser tube easily removable, you could mount all manner of motors and filament routing, etc on that part of the rail without having any concerns about moving mass.
Think about a build volume of something near 20"x11"x7" - nothing out there like it.
