hello fellow owners! i wanted to share some designs and this is my first one i’m sharing. i’ve had issues with my .svg files i’ve made on my computer not going through the glowforge app to make a cut file so i usually save my cut files as a .pdf and have no issues. i’m including a compressed svg file as well as a compressed pdf file if there are issues with the svg files. please leave feedback if you use the file as to whether you have any issues or successes. happy printing!
svg version: 45 adapter earings.zip (716.8 KB)
Yes, I use illustrator for my files. I had success using my svg files and suddenly one day I went to upload an svg file and it never processed through, but I have success uploading pdf versions I save from illustrator so I usually just use them
I appreciate your sharing! However, when I open both files, I see only 2 things on the file. Are there supposed to be 45 pairs of earrings, or just the one?
To be fair, I am old enough to have had “owned” adapters that were supplied with a player, but usually shaped like a deodorant can cap (closest thing I can think of) that snapped into a corner when not needed. I never bought a record that came with the big hole (although many had cuts so the inner part could be snapped out if needed.)
When I first saw this thread, I was expecting something to adapt .45 ammunition to some other calibre, which I have never encountered!
WAIT! Hold the presses…I have been reliably informed that the 45 refers to the speed the record turns, (revolutions per minute), and not the size of the opening!
