I have started to use PDF more. My wife has been learning vector design and Glowforge stuff using Affinity Designer, and I have found that PDF is the best way to move files between her AD and my Illustrator. With SVG you have the DPI issue to remember but PDF “just works.”
Totally knocking on wood while I type this, but I’ve literally never had an issue saving as Inkscape SVG - I didn’t see the warning until I was many designs in so never changed my system…
I do wonder what the issue is supposed to be - though if it’s layer based that’s probably why since I never “finish” a file that still has layers, I always compact before saving.
I don’t think it hurts anything with Inkscape. I’ve missed it now and then as well. I just don’t want my files containing any app-specific information.
This is interesting. I played with the file a little and noticed that if you copy the affected circle and paste it, the problem follows the copy as well. There seems to be something about that particular circle . Unfortunately I 'm not enough of an illustrator guru to compare the good circle with the bad one, to see what the difference is.
Looking at the paths of the circles, they are all centered. I used the anchor tool and examined the path for the circle that works and the one that doesn’t, I can’t see any difference.
The file you’re looking at never contained a circle, it was imported from the result of generating holes in Fusion 360 by loading a model of a screw from McMaster-Carr and subtracting it from my base plate, generating an SVG using the Glowforge Colorific CAM processor, cleaning up in Illustrator, saving back out, running through Deepnest, and then making another round-trip through Illustrator. I should be surprised it even works at all.
Thanks. It’s been a while, but I think all but BlinkFade are my creations. They all started life on the PixelBlaze but I’ve been slowly porting them from nice pleasant JavaScript to ugly low level C. Got a bunch more to go but I took a break to focus on the hardware.
i have no pixleblaze but I can make use of the code snippets on a few of these. inspired by this to try to port my 64 x 64 matrix designs into the 8 x 32 format. some of them will work, others will flail. I mostly use Arduino sketches based on FASTled and ledMatrix as the backbone for my patterns.
do you know if anyone is selling an all-in-one kit? 'cuz if I can just buy one and screw it together, I will get to it much more quickly than if I have to research every part. I have too many projects already!
