Acrylic Re-melting Together
Im cutting pink acrylic and it appears the acrylic is fusing back together before it finishes.
Im at 10 speed and 10 power. 4 passes.
Any tips?
I am guessing that you have the Aura or Spark. The diode laser will struggle or fail to cut many pastel acrylics. If it is fusing back together, perhaps you need to increase your speed. Where did you source the acrylic? How thick is it? Did the vendor suggest that it was diode friendly?
