This one was in the making for awhile, but i finally finished it up recently. My brother in-law’s band, Palette-Swap Ninja, released a parody album that mixed Star Wars and Sgt. Pepper’s.
I made this record light as a Christmas gift for him.
The inside isn’t that pretty, i had some issues getting the LED strip to stick so a little hot glue to the rescue. The front is held in place by the embedded magnets on the sides
Great work! Would you be willing to share the info about the led strip you are using? Is it simply a battery operated connection? Not much experience with LEDs, so I thought I would ask.
Here’s a little info about the LED strips I use. They look to be similar to the ones in @ianauch used here. If you search the forum there’s been a few posts about them.
The LED strip I used was just a cheap one from Walmart. It was one of their Bluetooth models. I ended up cutting the end off the usb and putting on a wall wart.
