I want to make my own light bases, but not deal with the LED part. I think I found a decent LED strip source and thought I’d share. Forget to mention it’s free shipping too
Edited to add: I just noticed it says “$3.99” in the link below. I didn’t pay attention and ordered from the US warehouse and paid $5.67. Apparently if you purchase from the Chinese warehouse and are willing to wait on shipping, you get the lower price.
I wonder how many LEDs this can run at a time.
I know with my regular wall plug strip if I turn up the brightness too much it will start flashing. I assume because it does not have enough power to run the whole strip
For what it’s worth, I bought an LED “can light” (to use as a backlight against the wall behind TV when watching in the dark) about 8 years ago - it uses that exact remote! And it still works
Thanks. I’m pretty lazy though and was looking for the pre-made strips. I just want to be able to make a base and stick the strip in without soldering etc. I haven’t been able to find them on Amazon. The ones I ordered made it to my door in less than a week so it wasn’t too bad.
You can get shorter ones - I just get the big reels so I can cut off how much I want. The shorter ones have the ends already wired in (4 pin connector) that plug into the controller - just make sure you get the right controller for the wire you get. The RGB ones have 4 pins so you can change colors. The single colored versions have 2 or 3 pins depending on what the controller will do to them (if there’s a controller at all).
Does anyone know if I can use Arduino to individually address each led on a strip? I have a project in mind where I need to be able to control which LEDs turn on. Thanks.
Yeah your best bet is to go to fastled.io. That library supports a huge array of LED types. I typically use 3wire style (ws2812b etc) because it makes soldering easy when you have a lot of strips in a project, but if you’re only doing one strip the 4 wire systems are generally better performers (apa102 etc).
