Is acrylonitrile-butadiene-styrene a type of acryllic, and can I use it in my Spark? There are some motel key blanks on amazon that I want to use.
ABS is laser safe (but not an acrylic), I believe the biggest issue is melting. AFAIK no one here has tried it in the Spark so you may have to test yourself!
Check out #6 in here:
Hello! You’ve been referred to this post because you have a common problem or question. Check out the list below to see what this post can do for you. Just click on a topic that interests you.
1: I'm new to Glowforge and really have no idea where to start Hey, welcome to the forum!
Glowforge has a getting started page, it’s definitely worth your time:
<a href="https://support.glowforge.com/hc/en-us/sections/11792517736475-Design-and-Print-Tutorials">https://support.glowf…
