Once upon a time I recall someone (Jules?) once wrote about a way to see the actual cutting area on ones GF… putting masking tape around the edges of the crumb tray and doing… ?
While the new update has increased the accuracy significantly, and I have a Pro model, I still haven’t screwed up the courage to use the pass through (wish the Glowmarks were still a thing), but knowing my actual edges would be helpful.
Does anyone have a clue about the edge…?
Import some lines to cut a rectangle out of a scrap piece of 12x20. Position and size them to be right at the edge of the printable area in the UI (they change color when you’re outside the working area) - using max zoom helps get right up to the edge.
