Adding a cutline
You need to use a vector drawing program like Illustrator to create the cutline (square or circle or whatever) first.
Then you save that file as an SVG. Once it is created, you can drag and drop the file onto the artboard in the Glowforge interface and there it is!
Since you mentioned using Illustrator, I’m going to point you towards some short tutorials.
These will get you up to speed quickly:
Then if you want to get started designing your own stuff quickly, the Matrix has a lot of tutorials and video links showing the best of the tips and tricks:
For using the Glowforge:
For Using Photoshop, GIMP and Paintshop:
For using Illustrator, Inkscape, CorelDRAW and Affinity Designer:
For using Fusion 360, OnShape, Openscad, Rhino, etc.
Have fun! :grinning:
