Is there anything up against the right side of the machine, or a piece of paper that may be stuck over the holes on the air intake holes on the right underside?
Doesn’t take much to interfere with proper air intake!
This happened to me when I started using stronger magnets than I had been previously to hold down my stuff. Every time the air assist passed over one, the fan would slow or stop and I’d get the error. Since I’ve been sticking with holddown pins (and weaker magnets when absolutely necessary) I haven’t had an issue.
So thread was about air assist fan, and now about not cutting all the way thru?
Yes it can be frustrating–no matter what material you use & the settings, always BEFORE you move the sheet, try to wiggle the item you cut out–if it moves, it’s free. if it seems hung up, run another cut pass. (I learned this after a few times of pulling out the sheet and “oh, sh*t”).
There are many reasons (due to physics & humidity among them that affects the effective power of the beam, or the water absorption/content of the material, and temp of the material (coefficient of expansion) that you don’t get full cut through.
Yes it’s frustrating, but learn to adjust your process to minimize lost material while there’s any analysis of the PG settings vs. material tolerances.
But to be most effective with your unit, especially if you start using non-PG materials, you must learn for yourself how to make adjustments to get your results. There are many, many threads from users over the past 2+ years on this machine that will likely help you out greatly, as long as you’re wiling to learn.
But alas for air assist fan issues, you’ll definitely need to wait for support to get back to you.
Yup, understand the frustration, but alas lots of other users that usually have great advice/suggestions will see that and back away… I do hope the support team is able to help you quickly–often though their first response is a “canned” one about trying this or that, especially if your info is not clear on all the steps you have tried, and often providing a date/time for the issues helps them when looking up the logs for your machine, too.
