I keep trying to cut a fairly large print (about 20+ minutes) on Proofgrade Medium Draft board. At exactly 11:01 remaining, I get the error about the air assist fan not running at the correct speed.
I have done the troubleshooting steps, cleaned the fan, etc. I am able to restart the print, and it fails again at the exact same time remaining. I don’t get this error on other prints. I have cut this design over a year ago and not had this issue, wondering if maybe an update has caused this? I find it really odd that I get the error at the exact same time.
Is there a way for me to print this starting at the 11:01 so I don’t have to keep recutting? Again, I don’t think there is actually any issue with the fan, I see all the bits and smoke blowing away… It seems like a bug.
Yes, but they are nowhere near the fan head when it stops. I have ran into that issue before, but usually the magnets are within an inch of the print head. The nearest one where it stops is at least 6 inches away behind it.
The air assist fan is about 4 inches behind the laser head. Is the magnet 6 inches behind the laser head or the air assist fan directly below the laser tube.
Yeah, I just cleaned the air assist fan again and am going to try one more time, also moved the back magnet over. I’ve only had this issue one other time that I can remember, as I cut with these magnets all the time, and was cutting 50+ minute engraves earlier with the same magnets, even ones behind.
Before they enabled the air assist speed sensor a year or so ago, If I stood behind the GF I could see my air assist fan slow down and stop every time it passed over one of the magnets.
I am wondering if it has to be in the spot for a certain amount of time for it to slow it down enough for the glowforge to notice. This print has a lot of complex cuts which causes the head to sit in the same area… Many of my other prints are not that way.
Thanks, I will have to see if there are some better ones. The ones I was using in the past that I found for free on here weren’t that good especially for the thicker wood (1/4"). I cut a lot of non Proofgrade wood, and the wood tends to be a little warped (but is also really good, and 5x cheaper). I think my best bet would be to put some shielding on the magnets, or buy some that have the shielding. I have some hard drive magnets with the shielding but they just aren’t big enough.
I’ve used both the first, original type and the one sided type (not T shaped). They seem to work better cut out of ply than draftboard and fit tighter in one direction than the other. My honeycomb’s holes are oblong. For warped woods I just pop in a few more pins in that area for more holding power.
I’m so sorry to hear about the snag you were experiencing, but I’m so happy to hear that the advice @ekla and @rpegg provided helped to narrow down the trouble. I’ll close this thread for now, but please don’t hesitate to reach out to us in the future if you run into any of the same behavior. We’re here to help!
