Air FIlter System
Can I hook up two glowforge units to one filter system? It is a space usage issue
Probably wouldn’t run both at once. It is likely an air flow issue.
Either it’ll back up and cause odor and smoke as not enough throughput or if it were to be forced through at a faster rate, not spending enough time around the charcoal will leave odor in the air.
Might want to send an email or call the support line directly so you get a company response.
The filter is an expensive solution for occasional use in an enclosed space, such as in a home or apartment. Two machines would certainly indicate you don’t intend this to be for just occasional use, so a filter is an inappropriate solution, you need to plan on venting outdoors.
