That’s it. Rank stuff. I stopped using extruded a long time ago.
BTW, you can get paint to make your own mirrored acrylic. Krylon & others sell it. A handy tip is to put a final coat of black on the mirroring paint to make it really pop.
Oh yeah. I didn’t word that properly. Get lots of smoke with most things that I cut. It’s just after the cut and fans have stopped, I lift the lid, then the board, and underneath a bunch of smoke wafts up from the bed. Far more with the MDF than the Proofgrade. Which is why would want the fans to run another 10-20 seconds more than they do now and stop if I lifted the lid.
Ah. Okay. Then I’m probably not experiencing higher smoke levels than everyone else. But I still have to check to see if there’s anything in the flexi hose like Takitus mentioned.
Otherwise I see the same behavior you do. MDF seems to be a particular culprit which I always attributed to it being almost all burnable - there’s no real “air” in it like there is with wood & ply between the fibers &/or layers. It’s denser and all that density burns under the laser.
You could always sell the filter after to those that ordered basics w/o the filter…
Hopperized! (cc @tony)
Please note that not all filters work the same way and not all remove the same contaminants.
Good point, thanks! I’ll double check what ours exactly does, but it is a big unit, and I’m sure the Glowforge doesn’t create anything as toxic as comes from polishing jewelry, or rhodium plating.
My installation solves that issue, it required 2booster fans for the 30’ of duct run and 4 elbows.
The 4 feet of flex hose required to allow the pull-out shelf connects directly to the first one, and it runs continuously so even after the forge fans stop the machine is still evacuated.
So because mine required 2 $60 booster fans, the evacuation and cooling are enhanced.
From the reports of lingering smoke I suspect even short runs would benefit from a booster.
