Alignment and calibration help
Alignment and calibration.
Hi friends I need help. I usually make smaller projects so aligning my board is not an issue however today I did a full 12 X 12 on a 12 X 20 prograde acrylic board. Unfortunately, I couldn’t get it to the very edges. Please see my picture and you will see the print area doesn’t align with the crumb tray.
Is this normal and can I calibrate it or what exactly is the fix? Thank you for your support and help on this.
The maximum cutting area is 10.95" tall (and ~19.65" wide.) It’s in the tech-specs.
That’s what the grey shaded areas are indicating in the UI, that is outside of the working area.
You’re going to have to shrink it a little bit or use the pass through if you have a Pro.
Oh I see thank you for that. I always thought it was 20 X 12 as thats the size of the proofgrade boards
I do have the passthrough but have not used it yet I am a little afraid it wont align.
The size of print space changes based on the print speed. :slight_smile:
