Alignment Error Map - What is acceptable?
One can see the alignment will be out when the outline of the board is not shown square.
Did anybody notice an improvement in accuracy in Dec? Examples like this seem just as bad as they ever were. The announcement implies there should be a big improvement if they have started using machine specific calibration data. Perhaps the machines shift in transit or need to be on a perfectly flat surface for the calibration data to be valid.
It would be interesting to see how it varies with a small shim under a corner.
