+1
The flashback seems consistent enough to be an embellishment.
I bought one of the bases also, and liked it so much I bought a dozen. The slot is an issue, too big for 1/8th and too small for 1/4. I still have to dial in the settings for the right depth of material removal for 1/4", which I favor the looks of above the 1/8".
Nice job there! When you see the piece light up, it inspires more ideas.
Looking at the depth of the deepest engrave in 1/4" as you go up the stack, shadows could be minimized by alternating which side is engraved.
Isnāt that weird?! Enough play to make it annoying, but itās not a show-stopper for me. I considered making some sort of sleeve, but I didnāt want to risk interfering with the light transfer.
I have some smoke-colored acrylic that could make a base topper with the proper slot. Otherwise, I plan on 3D printing an L-shaped shim for the back.
If I use 1/4" acrylic, Iāll have to do the engrave thing.
Too much work for my tastes.
Maybe Iāll cut some veneer to fill the gap. But Iāll probably just leave it alone.
Try the slot fitting engrave on the front and the design engrave mirrored on the back. Do a jig so the front lines up with the back & your ultimate cutout. It doesnāt need to have a lot of precision since youāll cut your shape at the end so if the engrave section is too wide youāre still good.
Yesā¦I get those, too.
Great minds think alike on this one.
It would be INSANELY fragileā¦ but you could have a small non-engraved bridge from the top of the āmā to the engraved apostrophe. Almost certainly no light would get to it, but it would at least be there :). I donāt know if this is the same bridge you decided against, but it is better than a full bridge up from the primary border
Thatās pretty much what I had consideredā¦and in fact never considered making it from the primary border. I will certainly be keeping these ideas in mind, going forward. This is so very much part of the funā¦learning all these new things. Thanks very much for your input!
Whatās the solution to the shadowing?
Hi, what have you found is the widest and highest you can go (of the engraved acrylic piece), while still maintaining stability while it sits in/on the led base?
