Things seem to be cutting okay, though wow this is a pain to look at (and embarrassing when trying to show off). I could do with much better precision (it’s blurry right under the camera too).
Mostly posting this to report it as an issue, but I’d love to resolve it. Happy to focus it myself if someone can tell me how.
Pretty sure the lens is glued in the production units. Probably don’t want to fool with it anyway. The focus on my Pre-release unit could be adjusted but the distortion/offset also changed if the lens was rotated Not a straight forward process…
It’s about the same quality, definitely out of focus. I haven’t tried twisting due to rumors that some of the post prerelease models were glued in. (“post-prerelease”? how about just “shipping”)
I just manually adjusted it until I got it as sharp as possible.
Lots of back and forth: rotate, scan, examine: repeat
I think I will mark the lens barrel with a white marker so I know where it belongs, as it will likely move when I clean it
The camera is locked in place to prevent it from coming out of focus.
These images look similar to others I’ve seen. It’s possible for the QR code to look blurry, but still be interpreted successfully by the app. Please let me know if the app doesn’t recognize your Proofgrade materials, and I’ll happily take another look.
I’m going to close this topic. If you have any other questions, please post a new one.
Mine will twist to change focus. I assume that’s the norm?
Although that image is not that far off from what I’ve seen.
Try putting some small print in the middle and see what the camera sees there.
@Houdini7 We try to keep to one topic per post in the Problems and Support section. Can you create a new post with this question?
