Hi @mrtoad. You’ll need to do some test runs to engrave the cutting board…basically getting some “sacrificial” material like plywood/hardboard to reach as close as you can to the same thickness of your cutting board. There’s some math involved. This is a great tutorial for engraving without the crumb tray Tutorial: How to cut without the Crumb Tray (Honeycomb) You’ll also want to mask the cutting board. See above for settings!
