Materials: all proof grade
(1) sheet solid walnut
(1) 3mm black acrylic
(1) 3mm clear acrylic
Note: Not sure how much I modified these after cutting, so don’t expect it to work first try. I was trying to press fit as much as possible. Also There is variance in the apple watch cable, I made 2 of these stands, and the cable disc was a different size. On the red engraved portions I did 2 passes.
Really close to my design. Main difference is on the watch stand, I ran the cable down the center section so it was fully obscured. The other reason I ran the wood layer on top was so I could etch through most of the under side for the plug on the wireless charger and still keep it covered. I also ran clear through the center of my base so the light ring on the wireless would still be visable when charging.
