Proof of concept here, settings in the pics below.
Quick and dirty alignment trick, blue tape on the honeycomb…
Line it up and score the outline…
When the score is done, you place the tile right on the outline…
Setup the engrave. I guessed entirely at the settings.
Turn off the outline score.
Engrave! (an hour or so to go a 1.75" square image)
Better light to see the depth of the engrave…
Ink it up… (black sharpie)
Wipe off the excess, and call it done!
That is a pretty deep engrave.
Looks great. Glad to see this worked.
That turned out nice, even though it took a while. I like your “quick and dirty alignment trick.” That’s an easy way to make a jig for one-ofs.
This 100% works in the as well
Beautiful work
My brain 100% read this as “Wipe off the excess, and call it glowforge”!
Yup. I do that too for several things, especially when reusing cardboard templates/jigs or needing a quick couple of coasters.
Huh, I’ve always used waste cardboard for a raised jig, but this is precise enough!
rvogt
July 31, 2023, 1:50am
9
This turned out nice. I like the depth of the engrave.
Good result for 1 pass. What kind of swarf did you get with that? Enough dust to notice? On travertine, I noticed a tendency for it to build up in the corners and fuse there, it had to be scraped out between runs.
Do you find the bed has the same dimness issue as the plus or pro?
Good to know! I thought it might, but hadn’t tried it. Thank you!
Dimness like in the UI photos? If so it’s not bad. The big difference is that it’s a single bright led in the middle, not strips. I’d imagine shadows might be a thing with larger items but I haven’t really noticed it with flat stock.
On the other hand it’s a small machine with a white interior so maybe the light will bounce around enough that shadows are filled to the point of being a non-issue?
A fair amount of swarf, but I was able to step outside and get it out with a nice dry paintbrush. Pretty typical from any tile engrave.
Learned another new word. Thanks.
Did you use a glazed tile or did you treat the tile with anything to help the Aura Laser work?
evansd2
October 23, 2023, 2:58pm
17
Just a plain small glazed tile from home depot.
what was the material setting used please and thank you
Welcome to the forum.
There is a screenshot of the settings shared near the original post,
