See the thread about balsa wood settings in “beyond the manual”.
Here is the file.
b25 rtc.zip (21.9 KB)
Here is the file.
I had unintentional engrave burn through on one of my double sided pieces but luckily it added to the look of the piece. I thought you boy might be interested in this B-17 piece:
Thanks for the file.
Oh, wow. My dad flew B17’s in WW2. I have been wanting to get around to making one. Thank you so much for this file. I am going to try it tonight.
If you want to try the same thing with the B-17, there is an SVG starting point here:
I took the similar file for the B-25 and basically cut it up into the separate pieces that are in the other file that I uploaded. So I copied, pasted, and then edited the sections for the fuselage and rudders in elevation view, and the wing and tail in plan view. Didn’t take very long to do - maybe even a little easier for the B-17 since there’s only one central rudder, which could just be left as part of the fuselage, vs. the B-25 which has the twin rudders at either end of the tail.
Good luck and let us know what you come up with.
p.s.: If you use a wood thickness other than 3/32, edit the slot dimensions for the various connection points.
