Then there’s moment you sit back to admire your work and realize you forgot to add a hanger on the back Hoping I don’t have to take it apart to screw in some suitable hanger, but I’m thinking I’ll have to as it’s kinda heavy and I don’t want to damage any of the LED strip inside. Any suggestions welcome; I want it to sit as flat as possible against the wall and I’m guessing it’s around 7lbs.
I don’t know how tight the backing board is to the front, but a keyhole cut into the backing board would make it as flush as you can get. You could also get the picture hanging hardware and then place stick-on rubber feet that are just a little more proud than the hardware on the back - that would make it flat against a wall. Not sure if what I’m thinking is coming across.
I think the bunny is absolutely, freakin terrific.
