Parameters to cut balsa wood of varying thickness from 1 - 8 mm. To minimize conical kerf, 3x passes are used. 300 speed is used. Correction for hardness is provided.
Power (%):
Thick (mm) Rep Speed Soft balsa Medium Balsa Hard Balsa
2 3 300 12% 19% 26%
2.38 3 300 14% 23% 31%
3 3 300 18% 29% 39%
4 3 300 24% 38% 53%
6 3 300 36% 58% 79%
6.35 3 300 39% 61% 83%
8 3 300 49% 77% 105%
A bit easier to read:
| Thick (mm) | Rep | Speed | Soft balsa | Medium Balsa | Hard Balsa |
| 2 | 3 | 300 | 12% | 19% | 26% |
| 2.38 | 3 | 300 | 14% | 23% | 31% |
| 3 | 3 | 300 | 18% | 29% | 39% |
| 4 | 3 | 300 | 24% | 38% | 53% |
| 6 | 3 | 300 | 36% | 58% | 79% |
| 6.35 | 3 | 300 | 39% | 61% | 83% |
| 8 | 3 | 300 | 49% | 77% | 105% |
And while these are good starting points, there’s no substitute for testing:
Thanks for posting your results.
