And the question of settings came up. So here’s the scoop…
This board was .4" thick bamboo. I hadn’t used it before and I didn’t do any tests. Usually I test new materials rather extensively. But I didn’t have any to spare, so… I figured I’d base my settings on Thick Maple Ply. As such, I used 1000/100/340. It turned out just the way I wanted it… Great contrast, yet not too deep.
@Tom_A if you want to experiment, Lowe’s Home Improvement has 4" x 4" x 0.420" thick solid bamboo flooring sample chips for 25 cents each. Pick up a dozen, have some fun
I tried cutting through one and that was a big negatory… after 12 passes at full tilt and getting about 1/8" into it, I got bored with the test. LOL.
Wow. Yeah I really should. My Wife picked up these boards yesterday and I had no idea they were bamboo until earlier tonight. I can’t believe you couldn’t get through at 12 passes?! Geez!
The Janka hardness test measures the resistance of a sample of wood to denting and wear. It measures the force required to embed an 11.28 millimetres (0.444 in) diameter steel ball halfway into a sample of wood. This method leaves a hemispherical indentation with an area of 200 mm2.
While that puts bamboo around 1300-1400, similar to oak. Lots of references say that strand woven bamboo is usually between 4000-5000!
Interesting thing is that bamboo isn’t really a traditional wood…its a reed. And those pieces are layered together. The hardness seems to come from the long fibers…reminds me of celery…lol
That’s interesting 'cause this sample piece I have is darn near impenetrable. Yes there was a small flame but still way less than with paper masking on non-PG acrylic. I thought I’d have problems but I had to give it full power and two passes to engrave. My first test using PG settings barely even tagged it.
My bet is since this was a piece of flooring, it’s probably made with a really tough binding resin and under high pressure to compact the strand fibers and make it solid as a rock.
I just did the cutting boards recommended from the materials supply thread, and while a speed of 1000 is great, a power of 100 is a bit much. I had my best results with a power of 80. Otherwise, my settings were those that were indicated in the first thread.
Great looking results! Thanks for sharing. While on the topic of settings, I’m wondering where to find the pre-selected settings when using a product on the GFUI. For example, if I choose “Medium Maple Plywood” where can I see the settings used for this product?
