Hello, I was getting lots of flames on my cuts and the cuts weren’t even going the whole way through. I started the process to clean out the fan but ran into an issue when re-attaching the belt. Most people have difficulty re-attaching the belt on the left side but I cannot even get it back on to the right side. There is no space to put the belt back on. HELP
There’s a screw head in that bolt - you can loosen it and move the bolt in to give more room for the belt. Go to support.glowforge.com and look for the instructions on adjusting the tension and it’ll have pictures etc.
3mm Allen wrench will undo it
@asianirae - did the instructions give you what you need?
