I just got my Glowforge Pro in last week and it looks like the crumb tray looks bent. The cuts seem to work fine, but I haven’t tested material in the corner that sticks up. Below is a picture of the crumb tray sitting on a flat table. You can see it’s about 1/4 of an inch off.
I also have a regular Glowforge, so I compared crumb trays. The crumb tray from the regular Glowforge sits perfectly flat on the table. It also sits flat in both machines. The crumb tray from the new Pro unit wobbles about 1/4 of an inch (back left corner… to front right corner).
The trays are supposed to be identical between the two units. Assuming there is nothing under the one that would cause it to sit incorrectly, would be very surprised if you aren’t sent a replacement tray. The trays are sold separately as replacement parts.
