Best Cut Settings
Is there a new engraving settings chart for the updated settings that Glowforge changed? I know the old chart was speed 0-1000 but it seems that they now have speed settings of 0-3300 so all of my cuts have been messed up since my old cut settings don’t work. I am slowly trying to create a list of what seems to work, but any support from the community would be great if some one made a new chart.
Welcome to the forum.
If your old settings were working, just use them and you should get the results you always got. Simply ignore the faster speed options. There really isn’t a need for a chart of Proofgrade settings as they auto populate.
If you are having problems with a specific material or design, post a photo and share your settings for more individualized assistance.
No chart is going to be meaningful. Either proofgrade settings work, or you find your own thru testing on the materials you have - which can then be saved in the UI.
Custom settings have never changed - settings I saved back from the very start still work identically today, despite changes to many things - including speed - in the UI. I have never used higher than 1000 speed other than for testing when it first was released.
