I have a couple of projects in mind where I want to conform some text to a curved shape. Not text that flows along a path, but text whose normally rectangular bounds are curved — some letters get taller or shorter, and their shapes follow the curved edge. (For example, the Netflix logo with its concave curve on the bottom.)
I know of some tools where you can apply this sort of transformation to any path, and it’s called something like Envelope Distort or Bezier Envelope. I don’t have (or particularly want) Adobe Illustrator, though, so I’m looking for an alternative (on Mac or iPad).
Inkscape looks promising, but:
The best I found in a web search is an article/tutorial/video that describes exactly what I want, but comes with an extension that doesn’t work. (Old code, no longer runs in Inkscape 1.0 betas. My hamfisted attempt to fix all the deprecated calls therein without fully understanding the code didn’t really work out, either.)
The built-in Path Effects has an Envelope Deformation that acts… weird. I’d expect results like those from the above article/video — e.g. if you curve only the top edge of the envelope, the distortion should modify the affected paths in only the vertical direction. Instead there’s this strange effect where it’s like you’re pulling on a rubber sheet, a vertical stretch causes a horizontal squish, and concave envelopes cause parts of the shape to flip over on itself instead of shrinking.
Interesting, but not surprising. I tried the T and it came out like yours (on the right) but if I turned off the left and right bends, it was different, but the vertical was deformed.
The netflix one came out as I would expect (2nd down) but when I turned off left and right bends, it deformed the N and X.
This took all of 3 minutes. If you need to do it a lot then yeah, I can see how you’d want some easier way to warp it, but as a one off, this was as simple as it gets using lines and stroke to path and whatnot.
You know what does have good mesh shearing? Gimp and photoshop. I might rasterize this text at huge resolution (like 600 dpi or more) and then go warp it in one of those, then get it back into Inkscape and trace it.
PS:
I also got bezier envelope to work just fine on inkscape 92x. It’s different from the live path effect… not perfect, but different.
