Most of the time when I do a trace I still need to “smooth” the traced object. AI has a feature to reduce the complexity of the trace which helps a bit.
I think the real advantage of using cuttle is to bring in bitmaps (scans of sketches) to use as reference and re-build using parametric objects.
In fact I was working on something like that last night.
updated: Finished piece Wave Tunnel Speaker
