Hey Everyone-
Thought I would share this all with you because I’m pretty proud of it. If your interested in how it was made or the files for it, here is a link to the Instructables build as well as my website.
I have yet to try leather. I will eventually but not ready to take that on quite yet. And hot glue is the best. Comes off cleanly with alcohol even if I get resin on it!
Thank you so much. You tube is a giant bear and probably just as much work as the project itself. I hope people find it at least interesting enough lol
Wow, so very cool! I actually tried doing some of that type of resin work using stained glass style frames cut from black acrylic. They came out terrible. It was just so hard to get the resin in all the little fussy areas without dribbling it all over the place. Clearly, I need to work on my technique. Your work is very inspirational!
I encourage you to try again. I ended up failing twice before getting to this. I found that doing a very thin first layer to seal all the edges with clear resin made a world of difference. NO Color bleed after that. Then i used a little carving spoon tool I had to be a stir stick and a little “eye” dropper for the resin. Don’t get me wrong…it took me a month to finish this. its not a quick project, but i think its so cool!
