Broken belt... need replacement
I had a small fire and the belt burned. I need a new one. No response for Tech Support… which Amazon products are compatible. We’re shut down at Black Friday… PLEASE HELP
Fires are not “expected” events, so belts are not a standard replacement part.
Posting here has opened a support ticket, so they will be along to close this discussion and continue to work with you via email. Usually within one business day.
I’ve seen several post with the same issue. I really need the replacement ASAP
The ‘same’ issue? You mean a fire? A fire that causes damage is user error so I just don’t consider that an ‘issue’ such as a roller breaking, do you?
“ASAP” is likely to be a minimum of about 2 weeks. If you need a working laser sooner than that you should check into local tech shops or possibly other :glowforge: owners in your area where you can rent time.
I can see that you’ve also reached out via email and that our support team has contacted you there. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic.
