The above is a simple spiral constrained within a square. The .pdf looks fine if I pull it up and prints fine on a laser printer yet when I bring it into Glowforge the complete spiral is clearly visible. It appears something is a bit off-kilter with the .pdf interpreter on the app. I tried a .SVG with the same results.
Yep. I have gotten the clip-path error on every corel draw export I have ever done over the last 7 years. I count about 1,500 different designs. This is the first time that it stops me from being able to use the design.
