Dice.svg.zip (34.4 KB)
If I try the attached SVG with the dice outline scored at 500 / 4, the #s at 1000 / 50 and the cut at 390 / full (targeting a thin material), the score lines are hosed.
Specifically, it looks like the diagonals are at too great a power and end up cutting through where some of the horizontal lines zip at a rather quick speed and score as expected.
In these pics, you can see the horizontals below the 20 are a bit lighter Same with the verticals. During the score, those particular segments were scored at a much faster velocity than the rest of the scores.
