I am using 3mm plywood and cutting things with a lot of fine detail. I seem to be getting a lot of burning. Wondering if I should decrease the power or the speed and if this will help? Thanks for any feedback
If you are seeing burning, in my experience, the laser is using to much power or not enough speed.
If you are using new material, I would suggest a material test. I learned about it here on the forum and it has really helped me dial in settings for material that is not
proof grade.
Thanks so much! appreciate the advice
Perhaps this was a typo? In case it wasn’t then you must remember you would have to speed up the laser or reduce power to it to get the same effect.
Spacing can sometimes be an issue too, I’ve found. if the path comes super close to another path, or overlaps, it’s like burning the same area twice, and overlapping cuts can result in more flashback (burning on the underneath side). Learned this the hard way on one of my earlier experimental pieces. Accidentally had some circles duplicated so it cut the same circles twice and BAM, burning on the back from flashback. And boy was it smelly and sticky, too (from the masking I imagine)
