Many, many files take up the entire print area and process easily and completely. 30mb seems rather large for duplicated keychains. When you say you created and then uploaded to AI, what program did you create it in? If you care to share the file, someone could weigh in and offer assistance.
Thats what i thought - I thought maybe I needed to compress or something - it does have alot of engraving but i’ve seen plenty of complex files already.
So i created it on the GF workspace -exported file - uploaded to Ai - then coped and pased across the full work canvas.
If you created in the GF workspace, just copy and past there. No need to export to AI. If there are lots of engraves, you won’t be able to use the entire print area as engraving requires room for the printhead to accelerate and decelerate in both directions for every line.
I opened this in Inkscape, copy and pasted and saved as a pdf. The file with 16 keychains is 2.3 MB so I’m not sure how many you had that gave you a file of 30 mb. key1.pdf (2.2 MB)
Keep in mind that if the pieces are a half millimeter apart that is sufficient. I have often done that to squeeze everything into the printable area. Having squeezed everything to the need if you make each horizontal row of images a single image it will engrave much faster. Doing so on the vertical provides no advantage.
Thank you - i’m not sure why it seems to be saving so big on Ai. Thats perfect - i can duplicate and make more. I was thinking about inkscape but since the youngest has me subscribed to adobe I thought i should try use it
Thanks again this is a big help
