I did an experiment, not with an epoxy saturated carbon though.
I made a carbon fiber part using cross weave carbon fiber cloth and âz-poxyâ finishing resin. the thickness is close to 3/32".
I tried high power at 332 speed for one pass and it appears to have cut the resin but the carbon fiber cloth was not cut. My second attempt was high power at speed 170 for three passes. I cut a 1" circle and it appeared to have cut the resin all the way thru but the carbon fibers were still holding strong.
I was able to trace the cut lightly with a razor blade and the circle dropped easily.
My findings are a mixed result; the glowforge cut the resin completely through the carbon fiber allowing me to easily free the cut material but it requires the extra step of cutting the cloth with a razor. For my needs it works well.
I should add that itâs not a clean cut due to the carbon fiber strands but a light sanding of the edges is all thatâs required.
I made a video of the entire cut but im not sure how to post it.
The SDS for that resin says about heating it:
- may generate toxic and irritating combustion products
- wear self-contained breathing apparatus and full bunker gear
- irritating and toxic fumes at elevated temperatures
- nitrogen oxides in a fire, which can react with water vapor to form corrosive nitric acid
Sounds potentially dangerous to the machine and the operator to burn.
HOLY CRAP!!!
I would avoid that in my 'forge like the plague.
it will probably dissolve the guts of the glowforge. ![]()
