Any suggestions? Can I remove barcode or it’s gono cause the material not being recognized?
Once it’s gone, it won’t be automatically recognized by the GFUI but you’ll be able to pick it from the materials dropdown list.
You can cut through it and engrave too but sometimes engraves will be affected by the extra thickness so I usually just flip the board over when that’s the last part of the material left to use.
Thank you for your help
The labels also tend to burn a bit more energetically than the PG material it’s stuck to. Didn’t cause a problem when all was said and done, but I was a bit worried as the laser started to cut in to the label and I saw that it produced a larger amount of smoke and a noticeable (albeit short) flame. Paid close attention for the remainder of the cuts in that area.
Thanks for the answer @jamesdhatch, that’s right! I’m going to close this thread - if you have any other questions, go ahead and post a new topic.
