I am trying to cut a Carrot, a solid carrot but it has double cut lines so it cuts the inside and the outside. I don’t want the inside cut I just want ONE solid piece. How can I do that? I am using the images from the Glowforge artwork.
Thank You
Thank You
I figured it out…there are solid images. I found a solid carrot, the more I looked. ![]()
Ok, I was just playing around with that and can not get it… ![]()
In that case I used the outline command to create a single shape out of three shapes. I did not know what carrot you used so I just grabbed one. In the case where you had 2 lines and wanted to get rid on the inner one, you could create an outline of the whole shape and get rid of both (or as with this Ignore them.)
Which carrot? You can export it and eliminate one line in Inkscape or other design software if the outline tool doesn’t solve your problem.
