I am still in the setup phases. I finally completed my venting setup, had my husband replace our 2-prong outlet with a CGFI 3-prong outlet, only to realize the outlet is still not grounded.
So my question is… since the GF Basic is a Class 1 laser, does that mean it definitely needs a grounded outlet?
If so, it sounds like we have a lot of work to do before I can even turn this thing on…
Without a ground, you run the risk of harming yourself and/or destroying your Glowforge (this applies to computers too.) Think of it this way, what would cost more, replacing your Glowforge or having an electrician rewire a couple outlets for you?
We had a separate circuit added for our Glowforge w/ Air Filter it only cost a couple hundred dollars.
Ground is definitely needed. Adding ground should not be that difficult if you or husband feel comfortable with electric repairs if not get a pro to do it. In the meantime an oversized extension cord to a grounded outlet can get you going.
As others in this thread have mentioned, to reduce the risk of electric shock or fire while operating your Glowforge, use only a properly grounded outlet with least 800 watts available.
I’m going to close this thread - if you have any other questions, go ahead and post a new topic. Thanks for the help, all!
