Hi. I ordered the pro version. I am into making pens, and I watched someone placed what looks like a lathe inside his laser cutter. You can see it here at about the 38 minute mark:
I tend to doubt it, but will there be a way to do this?
Thanks!
Well you can’t put a lathe in it, the depth is only like 1.5 inches. However, you can probably do it in steps. Print a bit, rotate, print more, etc.
Answer to you question is no. But there is some capability discussed in this topic. Personalized Wood Pens
